I am looking for a possibility to do the following as a pattern:
Trying to put that into a UDF, I was told by Creo, that it was not possible to copy a feasibility feature.
I would like to perform the above operations as a 2D dimensioning pattern, where the "lower" points coordinate increments are less than the "higher" point increments. This would result in smaller distance between the two parallel planes.
How can I do that?
I did it manually for 4 curves, but it is not possible to do it for my pattern application manually:
Is there some possibility at all, to generate the OPTIM1-Feature as a pattern?
