Hi folks,
I'm in need of a help in Piping.
Actually i've got a small piping assembly consisting of one Pipe and two end fittings at both the ends.
When I create a drawing for the assembly i'm trying to create a table to show the bend informations in terms of X, Y & Z using "Repeat Region". But the location info corresponds to the Assembly's def CSYS which is actually arbitraty and lies somewhere out of the actual assembly, hence making the Bend Info table meaningless to be used for reference in production.
Rather I would require the bend info w.r.to some co-ordinates that actually lie inside the assembly either of the end fitting's CSYS or the Pipe's CSYS.
I had attached the actual files and drawings.
Can some one help me out?? I'm dying for a solution!!!
Thanks!
AmarKarthi
