Piping welding and wight
gcontreras
could I weld the pipes to my assembly? Somehow it doesn´t permits me. I want also to calculate the weight of my assembly and I already added the Material to all the components. But the pipes I can´t add material, so their weight has not been added to my assembly. Is it possible to do this?
Thanks a lot!!!
Edna
1 REPLY 1
gkoch
(To:gcontreras)
If you create Pipe Solids you ge parts with appropriate mass properties.
Display Thick Pipes is just faking solids for display and hence you get no masses.
