Print to Pdf only print bottom left of document
BM_8212128
I have been messing around with the stroke to reduce file size and somehow change a setting and now the pdf is only the bottom left portion of the D size paper. What did I change to make this happen and how can I fix this?
TomU
(To:BM_8212128)
Sorry, I didn't mean pen table, I meant plotter config file.  Do you have a backup copy of the original plotter config file?  If not, can you please post the contents of what you currently have here?
4 REPLIES 4
TomU
(To:BM_8212128)
Are you messing with the pen table file?
Take a look at this setting:
BM_8212128
(To:TomU)
I have not adjusted the pen table just the pcf. Changed to full plot and still just prints the bottom left.
TomU
(To:BM_8212128)
Dale_Rosema
(To:BM_8212128)
Did you happen to save a copy of your config.pro that you can try and go back to the one before you started changing things?
If not, do you have IT resources that can restore a backup from last Friday?
