I have been messing around with the stroke to reduce file size and somehow change a setting and now the pdf is only the bottom left portion of the D size paper. What did I change to make this happen and how can I fix this?
Sorry, I didn't mean pen table, I meant plotter config file. Do you have a backup copy of the original plotter config file? If not, can you please post the contents of what you currently have here?
Are you messing with the pen table file?
Take a look at this setting:
I have not adjusted the pen table just the pcf. Changed to full plot and still just prints the bottom left.
Did you happen to save a copy of your config.pro that you can try and go back to the one before you started changing things?
If not, do you have IT resources that can restore a backup from last Friday?
