Pro/E Exits prematurely while saving an Engine assembly of 300MB size into Parasold/STEP format
akarthi
Hi ppl,
I'm trying to export a 300MB Engine Assembly file size into any of the possible neutral formats available.
My first attempt was with WF 3.0 MO70 into IGES format - Result the assembly was exported, but when I tried to open it again, got an error msg "Couldn't read IGES Data:
My Second attempt was again with WF 3.0 M070 into Parasolid & STEP - Pro/E exits Pre-maturely.
My Third attempt - WF 5.0 M090 into Parasolid - Pro/E Exits Pre-maturely.
My fourth attempt - Creo 1.0 F00 into Parasolid - Creo exited Pre-maturely.
Kindly suggest me any of the possible helps.. I'm hardly in need..
Amar Karthi.
Try to save as a shrinkwrap first and don't export the surfaces.
In Reply to Amar Karthi Arasan:
Hi ppl,
Amar Karthi.
Does anyone has a list of various pro purge programs that work for companies that don't use Intralink or Windchill, directories!
Evan C.
As I always say, you get what you pay for...
Not free, but very configurable and it works seamlessly...
http://www.wascotech.com/purgedrive/
akarthi
(To:akarthi)
Hi Michael, I tried to convert into a shrinkwrap model with Level 7, but I failed in this conversion too. But I found out that the Engine Block and the cylinder head in the assembly has got lot of Geom Checks, 1000's of Short edges & some 100's of burried features. I found this out by running the Model Check of these part files. Would this be a prob in my export actiion??...
