Pro/Engineer Boundary Blend Tutorial
SteveChoryan
In this tutorial i show people how to use boundary blend to fix a model that was imported and all surfaces. we use boundary blend here to fill the gaps and then merge those surfaces to create a solid.
2 REPLIES 2
great tutorial video..
thanks
Thank you.  I love the boundary blend tool.
I would like to share a little tip that I think began with WF5.  As long as the surfaces that are to be merged have no gaps and do not overlap, then you can select more than 2 surfaces, or quilts, to be merged.  I don't know if there is a limit.
