Process to edit fonts
khimani_mohiki
We currently use FONT on our drawings and we have an issue with the 1, I(i) and lowercase L being visually in indistinguishable. So we are looking to use ISOFONT instead, however this has an issue with the spacing of some letters.
So I would like to edit the ISOFONT to reduce the spacing between certain characters, I have gotten as far as:
1. Create new directory, add decompile_font.exe, compile_font.exe, isofont.fnt, ucore46.dll & udata46.dll
2. decompile the ISOFONT.fnt using:
decompile_font.exe isofont.fnt newisofont.fnt
3. edit the decompiled NEWISOFONT.fnt
4. recompile NEWISOFONT.fnt TO ISOFONT.fnt using:
compile_font.exe newisofont.fnt isofont.fnt
5. Move isofont.fnt into Common Files\x86e_win64\text\usascii
However when I re-launch Creo and try to change some text to the edited ISOFONT I get this error:
Font isofont.ndx.ndx can not be loaded
I presume this is a compiling error as I haven't touched the ndx file, if I understand correctly the ndx file just gathers various fnt files? Can someone shed some light on it please, I haven't been able to find any documentation on how to edit fonts, Im just making it up as I go along.
Many thanks
@khimani_mohiki wrote:
what does "set COMPILE_FONT_PMT=36" do?
in the past this setting wasd mandatory to get 64-bit version of compiled font.
Martin Hanák
4 REPLIES 4
I compiled Creo fonts in the past.
1.]
In Creo 5.0 installation I can find isofont.fnt file in Common Files\x86e_win64\text\usascii directory
2.]
In Creo 5.0 installation I can find isofont.src file in Common Files\text\usascii directory.
This means you do not need to run decompile_font.exe
3.]
In Creo 5.0 installation I can find isofont.ndx file in Common Files\text\usascii directory.
It contains 3 rows:
isofont.fnt
special.fnt
latin_1.fnt
4.]
To compile modified src-file I used following commands in Command Prompt window:
compile_font.exe   isofont.src   isofont.fnt
Martin Hanák
Martin Hanák
thanks, finally i made it work
