Hi, I'm having a problem with the EFX extention for Creo Parametric 4.0 M030
Whenever I try to add a new profile or part, it fails to do so and instead writes this:
which loosely translates to:
"Error when loading data.
An error occured while trying to load the part."
Is it on one machine or on multiple machines? Did you tried reinstallation ?
Anyone?
Hi @Camemberto,
sorry for the late reply.
I don't fully understand what you Problem is. Can you record a video or do some screenshots?
I've had that issue when inadvertently the working directory was changed and the created parts (framing pieces) in the assembly were stored in another directory. (default seemed to be the public documents folder?!?) Upon reopening the model, the system doesn't find the pieces.
Hope this helps.
