Is it possible to create projected reference points in Creo Parametric 2.0? If so, how can it be done?
This functionality is present in Creo Elements/Direct Drafting 17. See: http://www.ptc.com/appserver/wcms/relnotes/note.jsp?&im_dbkey=105261
Hi Romuald,
I just did a quick seach in our database on this but I haven't tested. It seems like something changed in Pro/ENGINEER Wildfire 4.0. What release of Pro/ENGINEER were you using before?
Here is a related document:
https://www.ptc.com/appserver/cs/view/solution.jsp?n=143762&source=tssearch
Hi Walton
thanks for your help
Our old proE version was proE wildfire 3
Hello Romuald GATINEAU,
Your generated the drawing in Pro-E WF 3.0 right?
While importing a drawing from older version to newer version the software will represent the dual dimensions above the leader line as per red color dimension in uploaded image. These were not changing by modifying in options also (Drawing options-- text orientation in dimension controls).
Thanks & Regards,
Naveen Kumar Gongu.
Hello Naveen Kumar Gongu
yes you're right the drawing was begun with proE-WF 3.0 and now i'm working on the same drawing with Creo 2
OK so if I understand there isn't really a solution
This document might help.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS25598&source=tssearch
