Dear All,
I'd like to filter 2d repeat region table for family table by value of parameter ,for an ex.
Same result I may get from filtering by instances by name
Software - creo 4.0
Thank you in advance for any suggestions.
Regards!
if you upload testing data (part + drawing) then you can expect my assistance.
Dear Martin,
I'm happy of getting your feedback.
In an attachment, please find an example - a reference model /with examples parameters/, a drawing with tables - as you have requested.
Thank you in advance for your support,
Regards!
BR
please create and upload testing data.
Dear Martin,
In attached file, please find data for test.
Regards!
below mentioned solution is related to my current knowledge. I think that Creo functionality is limited and you have to use some kind of trick.
I added new parameter MUJPAR into a part (two string values are allowed YYYYY, NNNNN ... these values are used on MUJPAR, only).
I created new table containing 1 main repeat region and 4 nested repeat regions - see picture below.
main repeat region ... whole table
4 nested repeat regions ... one region per column
cell[1,1] ... &fam.inst.name, filter &fam.inst.param.value == YYYYY
cell[2,1] ... &fam.inst.param.value, filter &fam.inst.param.name == DIA
cell[3,1] ... &fam.inst.param.value, filter &fam.inst.param.name == LEN
cell[4,1] ... &fam.inst.param.value, filter &fam.inst.param.name == PARAM_1
cell[5,1] ... &fam.inst.param.value, filter &fam.inst.param.name == PARAM_2
The table displays instances which have MUJPAR parameter value set to YYYYY.
In rr_filter.prt part instance MUJPAR parameter value can be set manually.
You can also:
See attachment.
Dear Martin,
Thank you very much for your outstanding support!
I have followed your path and got results that fulfilled initial requirements.
But, despite working on decent computer, I observed, with big tables thing get extremely slow - operations on tables are not optimized well in creo.
So I changed the method:
In the end it worked flawlessly and very quickly indeed.
It is a pity that Excel is not embedded in repeat region's functionality.
Thank you in for your support, and have a great rest of a day.
Pozdravy!
Best regards
