REPEAT REGION FILTERS BY PARAMETER VALUE
BR84
Dear All,
I'd like to filter 2d repeat region table for family table by value of parameter ,for an ex.
  • If certain parameter has a value of Y then row should be removed from the table /in drawing/
Same result I may get from filtering by instances by name
  • By additional suffix &fam.inst.param.name ==*x* or manual instances indication /what is limited by  character count in single line to 80/
  • But it is inconvenient / cumbersome
    • I have large family tables 100+ instances
    • Changes in filter, requires to change instance name - that has to match erp data
    • If few filters /few different tables are needed in drawing to show different variants/ are to be applied then fam. inst name is getting long and cumbersome
  • Filtering by parameters' value is desirable.
Software - creo 4.0
Thank you in advance for any suggestions.
Regards!
6 REPLIES 6
MartinHanak
(To:BR84)
if you upload testing data (part + drawing) then you can expect my assistance.
Martin Hanák
BR84
(To:MartinHanak)
Dear Martin,
I'm happy of getting your feedback.
In an attachment, please find an example - a reference model /with examples parameters/, a drawing with tables - as you have requested.
Thank you in advance for your support,
Regards!
BR
MartinHanak
(To:BR84)
please create and upload testing data.
Martin Hanák
BR84
(To:MartinHanak)
Dear Martin,
In attached file, please find data for test.
Regards!
MartinHanak
(To:BR84)
below mentioned solution is related to my current knowledge. I think that Creo functionality is limited and you have to use some kind of trick.
I added new parameter MUJPAR into a part (two string values are allowed YYYYY, NNNNN ... these values are used on MUJPAR, only).
I created new table containing 1 main repeat region and 4 nested repeat regions - see picture below.
main repeat region ... whole table
4 nested repeat regions ... one region per column
cell[1,1] ... &fam.inst.name, filter &fam.inst.param.value == YYYYY
cell[2,1] ... &fam.inst.param.value, filter &fam.inst.param.name  == DIA
cell[3,1] ... &fam.inst.param.value, filter &fam.inst.param.name  == LEN
cell[4,1] ... &fam.inst.param.value, filter &fam.inst.param.name  == PARAM_1
cell[5,1] ... &fam.inst.param.value, filter &fam.inst.param.name  == PARAM_2
The table displays instances which have MUJPAR parameter value set to YYYYY.
In rr_filter.prt part instance MUJPAR parameter value can be set manually.
You can also:
  • open family table in Excel
  • copy table contents into externally launched Excel sheet
  • compute values of MUJPAR in externally launched Excel sheet
  • copy computed values back into family table
See attachment.
Martin Hanák
BR84
(To:MartinHanak)
Dear Martin,
Thank you very much for your outstanding support!
I have followed  your path and got results that fulfilled initial requirements.
But, despite working on decent computer, I observed, with big tables thing get extremely slow - operations on tables are not optimized well in creo.
So I changed the method:
  • I sicked to 2d repeat region table
    • and did the filtering in excel
    • I found out, admittedly you cannot apply two and more criteria on names that include certain name, by can do the very opposite - you exclusion
  • I opened family table in excel
  • In excel I applied a filter on row
  • In parallel row I used CONCATENATE function /texts merging/
    • &fam.instance.name !== xxx /xxx is an instance name/
  • returned to creo
    • pasted Excel's merged values into notepad that was opened after - repeat region -> filter -> edit
In the end it worked flawlessly and very quickly indeed.
It is a pity that Excel is not embedded in repeat region's functionality.
Thank you in for your support, and have a great rest of a day.
Pozdravy!
Best regards
