As per the original post.
Hello Jose_Costa,
Quick question. Is the Video Link: 4874 still available?
Thank you,
Mike
RMB on tool bar and select Customize:
Search for Transparent and drag to toolbar:
I'm not sure what the video was, that was several community migrations back.
If you are asking about adding a mapkey to the tool bar, you can go to file options and add them to a quick access toolbar.
Hi StephenW,
Thank you for getting back to me!
From the description, the video may have showed how to make a mapkey for making parts transparent.
However, I just found out that Creo 4 has the "built-in" transparent option that I was looking for.
Thank you,
MS
I have a map key I created a few years ago, but now also have transparent and solid added to the quick access tool bar. If i click on a part the button is right there.
Hi Kdirth,
If you don't mind me asking, how did you get the Transparent added to your quick access toolbar? I'm using Creo 4.
So true! Every day is a learning experience with Creo 😁.
Thank you,
MS
Hi Kdirth,
Thank you, thank you, thank you!
Mike
