Reducing STL file size
jvo-2
I was wondering if it is possible to reduce the file size of a stl without damaging the integrity of its detail. I am trying to import multiples of the same file without crashing my WF5. Is there another software I could use that could do what I am looking for? Is this possible?
6 REPLIES 6
Dale_Rosema
(To:jvo-2)
Are you looking to edit the files? If so, .stl files are not friendly for editing.
Thanks, Dale
I do have some original files. When I send them out I do it in the stl format. Is there anything I could do if I do have the original part files to reduce the size of the stl?
dgschaefer
(To:jvo-2)
A reduction in chord height will reduce the file size. Typically I will set the chord height to zero, then Creo will issue a warning about the minimum and will set the chord height to the minimum for me. I then hit apply and check the file size. If it's excessive, I back it off in very small increments until it's manageable. Yes, it's technically a reduction in quality, but typically the difference isn't perceptible.
I'd agree with Dale, an STL file is great for rapid prototyping, horrible for editing or simply manipulating in Creo. Where you can, use STEP files instead.
LinkedIn
Dale_Rosema
(To:jvo-2)
As someone who used to do a lot of prototyping, you just have to play with the settings for triangulation. Go with something that you are comfortable with - the size of the detail on your part compared to overall size will change this also. Small parts with small details - more precise triangulation. The larger the part and not as fine a details, you can go larger. The only caution is the larger you go, the more circles will be faceted (the will all be faceted - think triangles), but the more you will notice it.
Dale
dschenken
(To:jvo-2)
jvo-2
(To:jvo-2)
Yes stl files not stp files
