Reference Patterns
JWayman
Reference Patterns
Another question to which I think I know the answer, but here goes:
In the case of a reference pattern, is it possible to selectively disable
individual pattern members? Like the little white dots in all the other
pattern types.
I create my reference features in my skeleton, use them to populate my
assembly with components, then things change, so I want to replace a couple
of the components with a different component. As far as I can figure out,
the only way is to change the pattern in the skeleton into two separate
patterns, each positioning a different component.
However, I hope you know different...
WF2, M220
jer3d1
(To:JWayman)
We have white dots on our reference patterns. [WF4]
(It is a smart option. Thank you PTC.)
All the best,
Jered
[cid:image002.png@01CAA331.0B9FFDC0]
I have the answer for the reference pattern issue:
It seems that Proe can't distinguish which pattern to reference if you
have more than one pattern in the same places, so you have to make
certain your reference pattern references exactly the same pattern or
all instances will end up on top of each other. The responses I got
follow:
The problem with reference patterns is that ProE has difficulty with the
reference pattern if the feature or component you wish to reference
pattern has references to multiple other patterns.
ProE expects just one patterned reference but if there are more ProE
places all the instances of the reference pattern on top of each other.
For instance, you placed a component with insert in a patterned hole and
a mate to the top surface, but you oriented it to a datum plane which
also happens to be patterned.
If you then wish to reference pattern the component ProE does not know
which pattern to choose as a reference and consequently places all
instances on top of each other.
I've mentioned this to PTC on several occasions. We need control over
the references you wish to use as a reference pattern.
Ideally would be that we can just choose any pattern to use as a
reference instead of one of the references of the first feature or
component.
It's great that since WF4 we can also disable instances of reference
patterns, but the ability to choose or change the reference pattern to
follow, regardless of the references of the first feature or component,
is the one thing that would make it complete.
So send in those enhancements requests and probably one day we will see
such an option.
We do quite a few carousels in our instruments so it's important to do
it right to avoid problems. For example, a carousel may have 24
positions with bearings, gears, etc. The first feature might be a bore
for a bearing, the second feature for that location creates snap ring
grooves for the bearing. The snap ring groove feature only uses the bore
geometry such as axis, edges, as references. This will allow the pattern
to be created correctly. HTH.
I've had the same problem many times and have not found a solution, only
a workaround. You can make some offset datums and hang the cuts on them,
and then group the new datums and cuts in a local group. You can then
pattern the local group. It does add some feature overhead to the model,
but I'd rather have overhead than not be able to finish a model.
I've found that the only time this has happened to me, it's because I've
used constraints that reference two (or more) different patterns. Said
patterns may be identical, but Pro/E doesn't understand that and doesn't
know which pattern to reference.
For example, maybe I've assembled a washer to a patterned hole, and
reference-patterned it to that hole. Then, when I assemble a screw, I
insert it into the hole and mate the underside of its head to the top
surface of the washer. If I try to reference-pattern the screw, Pro
doesn't know whether to use the hole pattern or the washer pattern as a
reference. Since I realized this and started making sure I only
constrained to one patterned feature/component, I have not had this
issue.
I usually see this when I accidentally select references from two
different patterns for my dimension scheme.
Make sure that the parents are only from the original pattern and you
will probably be OK.
Thanks to everyone who responded.
Ken Sauter
DRS Reconnaissance Surveillance and Target Acquisition
Infrared Technologies Division
PO Box 740188
Dallas, TX 75374
214-860-6826
NOTICE: This e-mail transmission (and/or the attachments accompanying
it) may contain confidential or proprietary information belonging to DRS
Technologies or the sender. The information is only for the use of the
intended recipient. If you are not the intended recipient you are hereby
notified that any disclosure, copying, distribution or the taking of any
action in reliance on the contents of this information is strictly
prohibited. Any unauthorized interception of this transmission is
illegal under the law. If you have received this transmission in error,
please promptly notify the sender by reply e-mail, and then destroy all
copies of the transmission.
"This (document/presentation) may contain technical data as defined in
the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10.
Export of this material is restricted by the Arms Export Control Act (22
U.S.C. 2751 et seq.) and may not be exported to foreign persons without
prior written approval from the U.S. Department of State."
