Relations in BOM
wfalco
Relations in BOM
I have a parameter called cage_code. I want the blank cage code in the bom column to read 96906.
I have another parameter called part_number. I want part_number MS51959-15's cage code to read 96906, which is currently blank.
I saw a tutorial on Youtube that showed the following relation that worked:
IF asm_mbr_part_number=="MS51957-15"
asm_cage_code="96906"
ELSE
ENDIF
This looks pretty straight forward and looks like it will work. Why does it not?
Do I need to do something to the cage code in the bom that reads &asm.mbr.cage_code? I tried something like &rel.asm.mbr.cage_code. That does not work.
Please help.
WayneF
16 REPLIES 16
StephenW
(To:wfalco)
The way I have handled this in the past is add a new repeat region relation parameter for the cage code, in my example, I use "new_cage_code".
I change the column in the table from asm.mbr.cage_code to rpt.rel.new_cage_code
new_cage_code=asm_mbr_cage_code
if asm_mbr_name=="MS51957-15"
new_cage_code="96906"
else
endif
What am I doing wrong?
StephenW
(To:wfalco)
There is always something that snags these up!
Does that part file actually have a cage_code parameter, sometimes thats the snag, and I sure don't remember how to fix that...
Unrelated:
Also, I noticed,  I used asm_mbr_name=="MS51957-15"  but when I looked at your setup again, you used asm_mbr_part_number=="MS51957-15"
So try changing to your relation to IF asm_mbr_part_number=="MS51957-15"
You are right. I needed to change name to part_number.
However - It is still not working.
The part does have a cage_code. But it is blank. I'm not sure if that has something to do with it.
StephenW
(To:wfalco)
Check this post https://community.ptc.com/t5/3D-Part-Assembly-Design/Repeat-Region-Relation-Blanking-Other-Cells/m-p/733329
I think you have to use the "if exists"
Silly relations will be then end of us!
IF exists("asm_mbr_cagecode")
	IF asm_mbr_cagecode == "12345"
	my_cagecode = " "
	ELSE
	my_cagecode = asm_mbr_cagecode
	ENDIF
ENDIF
StephenW
(To:wfalco)
And maybe a little of   this one too https://community.ptc.com/t5/3D-Part-Assembly-Design/Repeat-Region-Relation-and-Cagec-issue/m-p/739172
I hate repeat region relations!
Still no good. I wonder if it's cause its blank. I cant change the part file. Its locked. Relations are cool. But getting them to work is a frikin task. I wish there was a better way. Thanks for helping! I need a break. It's frustrating.
kdirth
(To:wfalco)
Below is my cheat sheet section on this.  Basically, you rename the repeat region relation and create a relation that controls the new name.
CHANGING ITEM IN BOM TABLE
  1. Select “Repeat Region” from “Table” tab
  2. Select “Switch Syms” then “Done.”
    1. If first item cell of column to be changed starts with “rpt.rel” go to 3.
    2. Double click on first item cell
    3. Select rpt… then rel… then User Defined.
      1. Type in Relation name- PRTNUM for part number/QTY for quantity/NAME for Description
  3. Select “Repeat Region” from “Table” tab
  4. Select “Switch Syms”
  5. Select “Relations” then select the table.
  6. Enter text to make change required and select OK/Done.
    1. Part Number change:
      • IF asm_mbr_name =="S12345_XXX"
      • PRTNUM="S12345"
      • ELSE
      • PRTNUM= asm_mbr_name
      • ENDIF
    2. Quantity change:
      • IF asm_mbr_name ==”S12345”
      • QTY="XXX"
      • ELSE
      • QTY=rpt_qty
      • ENDIF
    3. Name change:
      • IF asm_mbr_name=="SA47662"
      • NAME="XXX"
      • ELSE
      • NAME=asm_mbr_name
      • ENDIF
  7. Select OK
  8. Select “Update Tables” from menu then Done.
  9. Multiple changes in a column can be done by nesting IF statements:
    • PRTNUM="S12345"
    • ELSE
    • IF asm_mbr_name =="S23456_XXX"
    • PRTNUM="S23456"
    • ELSE
    • ENDIF
    • ENDIF
      • One ENDIF for each IF statement
wfalco
(To:kdirth)
Nice!!! Thank you. I will take another stab at this in a bit. It's frustrating as heck!
MartinHanak
(To:wfalco)
please read following information carefully.
1.]
I assume the parameter cage_code exists in all models
2.]
I assume no repeat region table cell contains &asm.mbr.cage_code
3.]
If the conditions from points 1 and 2 apply, then you need to add the parameter asm_mbr_cage_code manually in repeat region Relations dialog box. Parameter type selected is not important - Creo will change it to Unknown.
4.]
Put &rpt.rel.new_cage_code into repeat region table cell
Martin Hanák
BenLoosli
(To:wfalco)
Why not set the cage code in that part file?
Do you have the cage_code parameter in your drawing file?
I cant change the part. I don't have permission. I am back dooring this. The drawing? I don't know how that would work.
BenLoosli
(To:wfalco)
I got this to work.
Drawing repeat relations are:
IF asm_mbr_pdm_number=="MS9518-01"
else
if asm_mbr_pdm_number=="MS9518-03"
asm_cage_code="96907"
else
asm_cage_code=asm_mbr_cage_code
ENDIF
endif
MS9518-01 has a blank cage code, -02 has cage code 96545.
BenLoosli
(To:wfalco)
You need to replace our 'pdm_number' parameter with your parameter that defines the part number to the table.
kdirth
(To:wfalco)
Try this:
Edit repeat region cell for CAGE to rpt.rel.new_cage_code.
Relation:
if asm_mbr_name==”MS51957-15”
new_cage_code=”96906”
else
new_cage_code=cage_code
endif
