Remove Scale from Detail View
wfalco
Greetings,
Something I should know for sure by now. But.....maybe just never had the need to do this?
I have a detail view. It is Detail A. It comes with it's detail scale:
Detail A
Scale: 1/1
I would like to NOT have the Scale: 1/1 at all. But I do want the parametric "Detail A".
I tried to back space it out. No Go. I tried to erase and make a new Text using the syntax for "Detail A". No good.
Is this do-able?
Wayne
7 REPLIES 7
StephenW
(To:wfalco)
I just select that part of the text and change the font size to something really small.
Oh MY...LOL. I did not even think of that. Is it right? Is it wrong? Ha. Tx!
kpietila
(To:wfalco)
Wayne,
I am not able to do it either. But I did find that if you highlight the text, and change the text height to .001, it accomplishes the same thing.
[cid:image001.png@01D5B97A.D1921C60]
Ha ha...your the second one to say that. Tx!
It appears that you can select the note for the detail view -- and just delete or erase it... then add your own note and relate it.
The big draw back - there is no way to display the &view_name in your new note... Creo will reject that.
SO - if your view name is not going to change.. (like ever) - then you can possibly do that.
View scale would still be controlled by the view properties dialog.
Dave
Yeah....but sure as shootin the name is gonna change.
#totally 💁‍♀️
