Hi everyone,
I’m working with the team in charge to move to MBE, and I’ve run into a challenge I hope someone can help with.
I’m trying to remove the general linear tolerances that appear on every part (see attachment 1). I experimented with setting the "tol_Display" option to "no", which does remove the general tolerances, but unfortunately, it also hides all the local tolerances on features of size (see attachment 2 and 3).
Has anyone found a way to remove just the general linear tolerances while keeping the local ones visible?
I’ve attached a reference image to show what I’m working with. Any tips, workarounds, or settings I might have missed would be greatly appreciated!
Thanks in advance!
The tol_display config option has three possible settings: no, yes, and no_tol_tables. You might want to try the last one.
I did, but the result it's the same, both tolerances, local and general, are gone.
Set config option tolerance_standard to iso
For existing models and model templates set
File > Prepare > Model Properties > Tolerancing Standard > Standard > ISO/DIN
I tried the option you mentioned, and it successfully achieves the intended result (see attachment). However, since we are currently working on the project to transition our company to a Model-Based Enterprise (MBE), we primarily use models based on the ASME standard, though we also incorporate models aligned with ISO GPS. As part of this initiative, it is a requirement to manage the dimensioning and tolerancing system also represented within the 3D model. Therefore, this solution would conflict with that requirement.
Hi @EnriqueNunez ,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Hi, thank you for following up. I haven’t received a clear answer to my question yet.
So... you want the model to use the ASME standard but don't want to see that tolerance per decimal-places table in that graphics area?
That's not possible, AFAIK, except perhaps with this hack:
Set the "Secondary Highlight" color to be the same as "Background" color:
File > Prepare > [Detailing Section] Detail Options - CHANGE:
default_tolerance_mode: nominal
This will set the default tolerance to nominal, so when you place the dimensions, they will have no tolerance by default:
Only after you've changed it to, say plus-minus, the tolerance will appear. You can then select your tolerance table or set manual tolerance values:
Hope this is what you are looking for. If so, you can apply this setting in your speciffic template file - you can then select if for specific purpose only.
