Repeat Region table fitting on the sheet
NP
My repeat region (for BOM) is vertically extending for assembly and going outside of sheet. Is there a way to break or divide table so it does not keep growing vertically and could fit into sheet.
Thank you
MartinHanak
(To:NP)
@NP wrote:
Yes it did help. Although, I wanted to show all the footer such as item no. material etc. and also show the rest of paginating rows in one shot than individually showing each item row and then aligning each them.
Thank you for your help.
unfortunatelly I do not understand your note. I hope you used Add Title command from TBL PAGIN menu to add header row to each table segment.
Martin Hanák
4 REPLIES 4
MartinHanak
(To:NP)
you can split large repeat region table to several drawing sheets using Paginate command.
See https://support.ptc.com/help/creo/creo_pma/r6.0/usascii/index.html#page/detail/About_Paginating_Report_Tables.html
Martin Hanák
NP
(To:NP)
MartinHanak
(To:NP)
Martin Hanák
NP
(To:MartinHanak)
Yes it did work as you suggested.
Thank you
