Retrieving Simplified Rep
BrianKrieger
I am trying to ascertain a BOM without pulling up the assembly (traverse
the assembly structure). One way I thought of doing this was to
retrieve a simplified rep, but even that looks like it wants the
assembly in session first. Is there a way to.....
a) Directly create and open a simplified rep? I get a
ModelDescriptor error when passing a full path'd name (which means, I
assume, that the assembly must be in session).
b) Get the Assembly BOM prior to opening the full model?
I'm interested in non-interactive mode (i.e. using the retrieve with
options flag isn't desired).
Thanks, all!
Brian Krieger
1 REPLY 1
Just in case anyone didn't know, the only way to crawl assembly
structure (using JLink) is to have it in session. I still don't know
about the opening a simp rep to start, though. I'm assuming it will
still only allow the prompt and then you can create the simp rep once
it's in session.
BK
