Hadn't had time until lately to investigate playing with this again. It's a shape with a single side, and a single edge. I managed to fix it and get nice smooth tangencies, and the exact geometry I wanted (rate of OD change, rate of unfold to refold), and make sure the unfolded width was the same length as the circular section circumference. I just added a thickness to it so I can 3D print it.
Nice one!
'Sup Antonius! I sent you the real file via e-mail....unless it's changed. If so, lemme know. Hope you've been well!
Somewhat surprised Antonius was the only one to comment on this.......
The rest of us were overwhelmed and just sat back in awe.
Yep, pretty much!
LOLZ! Geez, usually that only happens when I do something colossally stupid (again...)!!
