Hello experts
How to create center axis for dia 25 in Drawing using CREO 8, Please some one assist me
The desired function is not available in Creo. You can submit an Idea to have this functionality added to Creo in a future release here: Creo-Parametric-Ideas
Until it is added, the easiest way to create the circular axis desired is to create a cosmetic sketch in the part modifying the line font in the properties for the circle.
I think Creo does not create requested axis. You have to add it by yourself as another model feature.
Martin Hanák
Thanks your reply
The issue is there is no option for axis creation (Revolved profile)
Chinnasamy
@Chinnasamy_P wrote:
Martin Hanák
Thanks your reply
Chinnasamy
this is not Creo issue. You have to understand that requested functionality is not implemented.
See uploaded part&drawing.
Martin Hanák
Thanks your answer
Actually circular part AXIS should be like this (Red in color)
Complicated drawing, we can't create manually. Other CAD software have option why can't CREO?
Parametric sketch option also not available in CREO 8.
Some Sheetmetal feature also not available (Example: Extrude wall filled option for bends missing)
Will see other answers, regarding this!
Chinnasamy
