I am using Creo Parametric 3.0 M190
In trying to run parametric in a script, it fails to start. Also, the CS116805 support doc seems not to be available:
Note: This article 116805 is not customer visible.
Here are the errors that I faced
application error: exception : ProEngineerStart returned ProError: PRO_TK_GENERAL_ERROR(-1), proe_path: "C:\Program Files\PTC\Creo 3.0\M190\Parametric\bin\parametric.exe" -g:no_graphics -i:rpc_input "C:\Program Files\PTC\Creo 3.0\M190\Parametric\bin\parametric.psf" %*, prodev_text_path: . Creo may fail to start if the Welcome screen has not been disabled.
Start Creo manualy and check "Do not show again" in the "Resource Center" window. See also https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS116805
The Local Service account does not take into account some of the environment variables that a local user account has. It is documented this way by Microsoft.
please provide more details about the script and the way how you start Creo.
In attempting to paste everything in (and re-running to make sure I captured the correct items), I've solved the problem.
The OpenMETA system (which called CREO) is launched by a Jenkins agent. I was starting the agent as a windows service. I used the Local Service account to do so. Apparently something deep inside CREO didn't like that (maybe there's an environment variable missing, or some such). Anyway, I made the service run as an actual user, and that cleared everything up. In case anyone else ever runs into this, the fix is no Local System users for the Jenkins Agent service if using CREO.
Thank you for your time!
