Save As PDF - Open file in Acrobat Reader - config option
Dale_Rosema
When doing a "Save As" pdf, the read opens unless you uncheck "Open file in Acrobat Reader".
This last for as long as the session does.
Is there a config option to "uncheck" this permanently?
Dale
mkajdan
(To:Dale_Rosema)
What we have done is saved a PDF export profile that has that box unchecked and created a mapkey to use that profile.  You'll need to set config option intf_profile_dir to the folder the .dop export file is saved to.
There is not a config option to change the default PDF export settings to a modified version.  An idea to do this has already been entered. 464380
4 REPLIES 4
mkajdan
(To:Dale_Rosema)
Dale_Rosema
(To:mkajdan)
I have created a PDF Profile. Now I am trying to set it with a mapkey.
How do I call it without creating a .pdf?
I would like this to be a stand alone mapkey that is run after starting up Creo.
Dale_Rosema
(To:Dale_Rosema)
I also checked the "Stroke All Fonts" on the "Content" Tab.
TomU
(To:Dale_Rosema)
You will need to select the desired profile while recording the mapkey and creating the PDF.  The mapkey will work with any drawing as long as you're not manually touching the output file name while recording the mapkey.
