Setting up Modelcheck
dbreen
At the company i work for we're using Creo Parametric 3.0 M030. Last half year we've been busy setting up Creo and at the moment i'm looking into Creo Modelcheck. So far it's not clear what is possible and how it has to be done. Therefor some information and expertise on using Modelcheck is welcome. Below are a few things i hope to achieve by using Modelcheck, if it is possible:
  • Check if units are set to mmKs, if not change it to mmKs;
  • Remove unwanted parameters: "Parameter_1", "Parameter_2" etc.;
  • Add parameters defined in the assembly and part templates, if not already present in the part.
Thanks!
Dave
4 REPLIES 4
TomU
(To:dbreen)
There is a new book out on the subject:  ModelCHECK for MBD
STEVEG
(To:dbreen)
I'm not sure the first one is possible.  It might be.
The second and third one you list is possible.
BenLoosli
(To:dbreen)
That book is a MUST buy if you have to set up ModelCheck. I bought it from Amazon the day after it was announced.
I have a zipped folder of various notes on ModelCheck gathered over the years and The ModelCheck Handbook should replace all those old notes.
Lots of ways to set up and use ModelCheck (lots of decisions to make).  Attached one-page diagram represents the very simple approach that we currently have in place.  May be helpful.
