Sheetmetal Flange is connecting with adjacent walls
angird1990
Hello all,
Thanks for looking into my problem.
I noted this while working with flange.
Image "1" is a simple planar and then i created a flange(refer to image "2"), which is a flange wall. Then when i add another flange to both the walls (refer to image "3"), the flanges are connecting in some area. I've marked that area in black.
I cannot remove it using miter tab and the edge treatment tab is greyed out.
Please help me out
Thanks in advance
kdirth
20-Turquoise
(To:angird1990)
The proper method depends on exactly what your goal is.  From your description, I believe you should be using 3 flat walls, modifying the sketch for the two side walls to create the desired joint at the corner.
Flange is meant for creating a single wall that follows a curved path.  Your result is exactly what a flange meant to do.
angird1990
(To:kdirth)
Thanks for replying.
Actually i am designing an enclosure for a machine. So i just created a sample model for briefing my problem.
In my case, there would be 3 walls similar to the shape of U (refer to the image). On top of every wall, comes a 90 degree bend and so does the problem. On every adjacent area the flanges are attached even after increasing the gap in miter cuts. So i doubt the manufacturing feasibility. Is there any other option to avoid that or am i doing it wrong?
