Sheetmetal reset settings
Dom_CHENTRE
Hi, I'm working for many years with a supplier.
So, I was  using its templates.
A lot of relations, parameters...
Now I would like to reset all of this this and use standard PTC standards.
Is it possible ?
How to know if everything is reseted .
6 REPLIES 6
BenLoosli
(To:Dom_CHENTRE)
Create a new template file.
Uncheck the Use default template box and use an empty template.
You will have nothing, not even a coordinate system or planes.
Patriot_1776
(To:BenLoosli)
'Sup Ben!  What's with the "trophy" symbol?  Do you get that when you're to a certain limit/gemstone, or is it because of being on a committee or something?
Community Champions get the trophy.
I guess I come off as knowing something about Creo and Windchill!
Maybe this movie quote applies: "Indo has forgotten more about dispensing pain than you or I will ever know."
Ah, missed that, thanks Dale!  I'd also nominate a couple guys who have contributed a lot, but simply haven't been on here in a while:  Tom Dirriwachter and Brian Martin.  Dunno whatever happened to them.
Dom_CHENTRE
(To:BenLoosli)
Thanks Ben,
However, I have some old sheetmetal parts, with qpecifics relations and bending table.
Is it possible to reset all of this ?
Using skeletons, geometric copies...
Not simple to desing them again.
