Showing dimension as limits in drawings
AnkurAggarwal
Hi All, While we show the dim as limits, the dim is displayed as upper value at top and lower value at bottom. eg. 50.1 49.9 But i want to show it opposite, like- 49.9 50.1 i.e lower value at the top and upper value at bottom. Actually I want to show bore dia of hole. And MMC shud be at top and LMC shud be at bottom. Is there any way to show it? Thanks Ankur
Change the tolerance mode to Plus-Minus, add a minus sign to each tolerance, then switch back to Limits.
