Hi all,
I have an assembly drawing with two representations - machined and stock.
Master rep is similar to Machined rep.
I have 2 sheet drawing, 1st sheet is stock and 2nd is machined.
How do I show weight of stock on 1st sheet?
Ankur
Hi
You can copy and paste the annotation in the Bom-tabel of that view to where you want it.
I know because I do so.
Regards
Chris
Thanks Christiaan. Can you please elaborate.
My assembly is having two simplified reps - Machined and Stock. I am unable to get the weight of "Stock" rep. "Machined" rep is Master rep.
Ankur
One option may be creating an external simplified rep of the stock rep. You can add the external rep as a model to the drawing and it's mass should appear correctly. Otherwise it appears PRO_MP_MASS always reports the master rep mass.
