I am using Creo Parametric 5.0 5.0.5.0
I made a video of the issue
https://we.tl/t-sVx4DpoAdx
Here are the errors that I faced
The function cannot be achieve
Since your part is created using an educational license, most here will not be able to open it. I built a model based on the video.
Swept blend works as I would expect it to for this shape. I suspect that your sweep trajectory may be the issue. Try to locate the proximal and distal ends of the trajectory within the sections and not on the boundary.
Blend trajectory
I can't imagine you will get many clicks on that link. You will either need to upload the video to the community or maybe youtube.
thank you for this advise , it's done !
Blend trajectory
And it works :
thank you very much
BR
VV
