Skeleton modelling reference sketch
AM_10846562
2-Explorer
I am using PTC Creo 8.0 and I need to do a model about a real object ( an old calculator), and I don't know how to start the sketch.
If somebody could send, how the reference sketch looks like (for skeleton modelling) that would be a lot of help.
The pictures show the calculator.
3 REPLIES 3
tbraxton
(To:AM_10846562)
With regard to skeleton modeling strategy, you will need to provide more details what you are attempting to use the skeleton for. To reverse engineer a master model of the molded housings of that calculator, I see no need for using a skeleton.
You can import your photos into a Creo model to use as a reference when sketching. Ideally you will get photos of a top and side view (orthographic projection views) and import them into the top and side planes in a model. You can then use these as a guide to create the sketches needed to capture the form factor in the Creo part.
Details on how to place an image on a plane:
To Insert an Image on a Datum Plane or a Planar Surface (ptc.com)
About images in Creo:
About Images (ptc.com)
This is an example of how images from a drawing were used to create a Creo part with the drawing views imported as a reference.
Involute Development, LLC
Consulting Engineers
I need the buttons to be able to move. How do I start?
tbraxton
(To:AM_10846562)
Are you asking how to create a motion skeleton model? If so, here is a tutorial on how to get started.
Sketch a Motion Skeleton | Tutorial | PTC Learning Connector
