Snap Lines not moving with Drawing
Garrett317
After I add a snap line and apply a construction line or reference line to the snapped portion, sometimes I need to drag the part drawing to a different spot on the template, however, when I do move the drawing, the snapped reference/construction line stays. Is there a way to fix this issue?
I don't understand what you are saying you do. I use snap lines around drawing views all the time to space out dimensions evenly. You seem to be implying that you can snap sketched geometry to the snap lines, but I don't see that behavior. I can't create a line that is "snapped" to the snap lines, and I can't create a line and then move it to be associated with the snap lines.
The only way I know of that you can ensure sketched geometry in a drawing moves about and scales with your views is to select it, then use the right mouse button to "relate to view".
2 REPLIES 2
Relate to View worked! Thank you.
