I am using Creo 4.0 and I just want to make a simple curvature continuous round. I used to have to do this manually without the advanced surfacing package, but I was glad to see curvature continuous constraints built into Creo 4. However, with those constraints and tangency constraints, this spline shown IS NOT SYMMETRIC. I tried to constrain the control points and use a control polygon, but none of it yields a symmetric spline! What is going on?! I'm downloading Creo 2 now to see if I can get my simple spline back.
"simple" curvature continuous spline round
Hi, I am on Creo 2 and the 2-point spline is symmetrical as shown below:
Thx, but I need at least one control point in the middle of the spline to approximate a simple round.
This is with a control point at its mid span:
It looks symmterical but actually it is not. I mirrored the cure and it does not overlap exactly to the original one:
wow thanks for doing this. I used to constrain the control points as much as I could and I assumed it was symmetric. The newest version of Creo 2 doesn't allow constraints on the control points anymore. what build are you running?
M240
Instead of sketching out the section, possible to make use of the options in round feture?
that's not a good idea when it's a primary surface. can't have a round that low on the feature tree because they break all the time. need to draw it right in, and need to be able to control it.
what about modeling half of the curve and mirror it .
Unfortunately the mirroring of splines has been a problem with proE for a long time. To do it effectively, I would have to go outside the curve and mirror the spline in a separate curve with a mirror feature, and I wouldn't be able to guarantee curvature continuity across that mirrored feature--only tangency.
After a few weeks trying to do the same things in Solidworks, I have to say that their spline mirroring and spline control features are actually better. I can actually very easily make this same spline symmetric about that 45 degree centerline.
Hi, I tried this workaround and it may work for you as well. I use a contruction curve(an arc in this case) for curvature reference before mirroring.
The curvature is then mainatin across the mirro plane and symmetrical. I attached the creo2 file for your reference too.
Available Curve Controls
This is a 3-point curve. It is not bound tangent, rather it is optionally dimensioned to be tangent.
By doing this, it also gives me access to the curvature dimensions.
And I can fix the center vertex orientation by dimension.
The most problematic thing about curves with 3 points is that you have to know that each end is exactly the same length. Position along the curve is not managed anywhere that I can find.
My results here are Creo 2. Somehow I am not holding my breath that anything real was done between Creo 2 and Creo 4 on these antiquated curve features. Just wanted to show you there are some hidden features!
