Spool in Piping
RussC
6-Contributor
Spool in Piping
What does the spool icon do in Creo piping? It's in the fabrication section of the ribbon. It seems to always be greyed out. I can't find any information online to explain what the feature does or how to use it.
2 REPLIES 2
Kevin
(To:RussC)
Spools are used in Creo Cabling not Piping.
Russ
The spool functionality in piping allows you to define a prefabricated part of the piping system that includes the fittings, pipe and flanges which are pre-mounted in the fabrication facility and later transported to the field.
This is only available in spec driven piping (set configuration option) piping_design_method.
The piping spool is different from the cabling spool that kevin referred to
thanks
Jim
