Stack Simple Balloons
svillafuerte
I'm pretty sure I know the answer to this question already but thought I would put it out there. Is there a way yet to stack "simple" BOM balloons and still have the numbersupdate parametrically with a repeat region table? I know in past versions the balloons always had to be "With Qty" type balloons for this to work. I just can't believe this has been that difficult to make work and come out in the newer releases of Pro. We do not use Qty balloons, we only use simple balloons so it would be nice if there may be a work around or something.
FYI -working on Wildfire 5.0 M030.
Shane V.
Shane, I have done this in the past, but I had to use a custom balloon. Basically, it was a symbol that had a circle with the item number inside (no quantity) but it will allow formerging, splitting, etc. Regards, Irawww.prohomepage.com
