Slightly off topic, but this has gotten me thinking....
How much is a monitor? Couple hundred bucks? A thousand? Miniscule when you start thinking about an engineers time and productivity.
2080 working hours in a year minus vacation and holidays
$50, $60, $100 per hour shop rate?
Doesn't take long before you overtake the cost of a monitor, yet companies in general are too short sighted to see it. The monitor is a hard cost, but the savings are soft, they will never drop to the bottom line, so they don't do it. And shoot themselves in the foot.
Doug,
I would rather have two $250 24" displays than one $500 26". You just can't put two prints side by side on the single large monitor like you can on the dual setup.
In both cases I keep ProE's main screen on one and push the model tree and menus to the other. A big change when you get a 2nd screen is that you almost never make paper copies of reference material any more. I use the 2nd screen to look at other drawings, the old print, spec sheets... as I design.
I can't say the Dell's are worth the extra money, but I wouldn't turn them down
Bryan
Looks like I'm going to get a single 26" NEC
