Hi all,
A supplier has sent us a step of an assembly file that we will be using.
I want to import it as a single part but when i do the assembly model looks like it loses its' constraints and 'falls to bits'.
Any advice is appreciated.
I use notepad editor and add the line to the config.pro file, then reload the config.pro or restart creo.
There is a HIDDEN config.pro top you can manually add
inft3d_in_as_part YES
Once added, you can import an assy as a part and the parts will retain their locations correctly.
I recommend removing the option afterwards, it's hidden, so it may cause unintended effects.
Thanks Stephen, how do i access the hidden configs?
Cheers Stephen, that's worked 👍
