To address the appearance for the surfaces, decals offer a solution.
You can create the desired topology to define the surface shape as desired, but you will need to create the geometry in the model.
The warp tool is one option.
I will try both decals and warp tool, and report back, but I found out that what generally applies to the surface of the part, does not necessarily apply to the surface of an extrude created on said part. I need the extrude surface to be different from the part surface.
Maybe I'm misunderstanding the problem. But it sounds like you want the face and text to be a different color than the rectangular base.
If so, you can apply different colors to different surfaces. Go to VIEW - APPEARANCES, select your desired color, select the surfaces you want to color, then press mouse middle button to finish. The colors only show in shaded mode though.
Hello @cgherghe-2,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
