Here is an example of the symbols for ‘GN’ for upper limit and ‘LP’ for lower limit. How can I define them in creo?
I don't know that you can add it to the format of the tolerance but you can add it to the dimension text.
Hey, thanks for your answer!!
I have already tried this, but got the following result:
If I deactivate the ISO display style, it is also wrong:
do you have an idea?
Looks like your Display option and text style so not work with the symbols. I think the best you will be able to do is add an offset note with the symbols and adjust the style height to fit.
