Symbols for asymmetrical tolerances E.g. ‘GN’ for upper limit and ‘LP’ for lower limit
MW_7632680
6-Contributor
I am using Creo Parametric Release 8.0 and Datecode8.0.11.0
According to ISO 14405 - 1, it should be possible to further specify both tolerance values with a symbol in the case of asymmetrical tolerancing. E.g. ‘GN’ for upper limit and ‘LP’ for lower limit. How can the symbols be assigned to the tolerance values in Creo?
4 REPLIES 4
MW_7632680
6-Contributor
(To:MW_7632680)
Here is an example of the symbols for ‘GN’ for upper limit and ‘LP’ for lower limit. How can I define them in creo?
kdirth
(To:MW_7632680)
I don't know that you can add it to the format of the tolerance but you can add it to the dimension text.
MW_7632680
6-Contributor
(To:kdirth)
Hey, thanks for your answer!!
I have already tried this, but got the following result:
If I deactivate the ISO display style, it is also wrong:
do you have an idea?
kdirth
(To:MW_7632680)
Looks like your Display option and text style so not work with the symbols.  I think the best you will be able to do is add an offset note with the symbols and adjust the style height to fit.
