Aug 3, 2021 6:08 PM UTC
Symmetric revolve 359.75 degrees
I'm pretty sure I could do a symmetric revolve up to 359.9 degrees in previous versions of Creo.
Could someone let me know if that is true?
I am using Creo 8 right now and it's maxing out at 359.5.
StephenW
Aug 3, 2021 6:25 PM UTC
I'm on Creo 4 M130 and I max at 359.5.
SYNDAKIT15-MoonstoneAuthor
Aug 3, 2021 7:34 PM UTC
The reason this came up is because I thought I could do it before but when I just tried today it wouldn't let me.
I decided to grab some older models to see and yeah I could do 359.9.
Furthermore, I can copy that feature into other parts and it works okay, I just can't create a new revolve feature and rotate it symmetrically 359.9 degrees...... weird.
Here is the part I'm talking about:
Chris3
Aug 3, 2021 7:27 PM UTC
Have you tried changing the accuracy?
Chris3
Aug 3, 2021 7:29 PM UTC
I can do 359.9
Aug 3, 2021 7:31 PM UTC
Change it to symmetric and let me know.
Aug 4, 2021 4:58 AM UTC
INFO:
In Creo 3.0 M190 I can create 359.99 symmetric revolve using PTC solid_part_mmks.prt template (attached)
In Creo 8.0.0.0 I can create 359.5 symmetric revolve (only) using  the same template.
Please ask PTC Support to explain Creo behavior.
Aug 4, 2021 12:36 PM UTC
Martin,
Your're the man!
thank you.
StephenW
Aug 4, 2021 11:15 AM UTC
It's an odd thing, like it is hard-coded in as a limitation. It's not like a regen failure due to accuracy issues.
But I do think Frank is right, Creo doesn't like itty bitty slivers.
kdirth
Aug 4, 2021 12:38 PM UTC
The only thing I can offer is a work around.  Sketch an arc and use a sweep.  I have been able to create a 359.998 degree surface with this method.
Aug 5, 2021 6:05 AM UTC
Chris3
Aug 5, 2021 10:01 AM UTC
Sounds like one of those cases (I have run into a few) where the programmers were like well this is too complex of a math problem to solve so we are just going to make an arbitrary limit that we know will work.
