THE Info Menu ERROR
visu
7-Bedrock
THE Info Menu ERROR
Dear Folks
I try to take BOM from Info Menu
But the systems opens new window with blank and says error.
while try to take BOM for Piping and Part's & Assy's.
please view pelow pictures.
any solutions.
Thanks in advance
Viswanathan.K
1 REPLY 1
MartinHanak
(To:visu)
Visu,
you can:
  • test BOM command on simple assembly containing one part
  • rename your config.pro file and test BOM command
This way you can find whether your problem is related to your assembly or your config.pro file
Martin Hanak
Martin Hanák
