Tabulated part?
designerdude
Tabulated part?
GTOL verses SHOWN/CREATED dimensions!!!
I have some parts that I want to tabulate on the same drawing. Usually I just create the dimensions and change them to read "A", "B" etc.
This works.
Since we are doing more and more GTOL dimensioning, The method above does not work since you can't modify a SHOWN dimension using the "O" in place of the "D".
If I use CREATED dimensions, GTOL doesn't work with them as far as I know.
Any and all suggestions, ideas or whatever will be appreciated.
Michael R. Deering
On shown dims, while you cannot use the 'O' method to clear the dim
value, you can display the dimension symbol by using an 'S" in place of
the 'D'.  Changing the dimension name in the dimension properties to A
will give you the same results.
Doug Schaefer
LinkedIn
Two part to this answer.
If you want to have a shown dimension appear as A or B, you can change the
dimension name from d123 or whatever to A or B and then instead of @o or
@d, you can use @s which shows the dimension symbol. In this case the A or
B.
A word of caution - This also creates a parameter called A or B. No harm
done and they can be useful in equations, but you should be aware that it
is happening.
Answer 2 - you can indeed attach GTOL to created dimensions. Our .dtl and
config.pro files are set up so that it works, but I cannot seem to find
the settings.
Can anyone help us here?
Bob Frindt
Sr. Designer
Parker Hannifin Corporation
Parker Aerospace
Gas Turbine Fuel Systems Division
8940 Tyler Boulevard
Mentor, OH 44060 USA
direct (440) 266-2359
cell: (216) 990-8711
fax: (440) 266-2311
www.parker.com
"Deering, Michael R (IS)" <->
03/09/2011 07:21 PM
Please respond to
To
cc
Subject
[proecad] - Tabulated part?
just create the dimensions and change them to read ?A?, ?B? etc.
This works.
not work since you can?t modify a SHOWN dimension using the ?O? in place
of the ?D?.
If I use CREATED dimensions, GTOL doesn?t work with them as far as I know.
Michael R. Deering
Site Links: View post online View mailing list online Send new post
via email Unsubscribe from this mailing list Manage your subscription
Use of this email content is governed by the terms of service at:
privileged. It only should be used or disseminated for the purpose
of conducting business with Parker. If you are not an intended
recipient, please notify the sender by replying to this message and
then delete the information from your system. Thank you for your
cooperation."
