I am trying to make one plate as transparent in my assembly. But it resulted in improper way. I am getting lines on the part like the transparency looks like shattered glass.I have attached the image. Help me out. Thanks in advance.
you graphic card is not supported. Creo needs dedicated graphic card with support of OpenGL 4.x
MH
transparency problems can be related to graphic card. What graphic card is installed in your PC ?
Example:
MH
Thanks for your reply i think its standard VGA graphics card.
MH
Thank you Martin Hanak.
