Turbine_Blade
osiddiqui
Turbine_Blade
help me to close an open loop of surface,further please guide me how to smooth surface on part.....every opinion is appreciable.
5 REPLIES 5
Hello Osama,
Your file is in a student version, it may not be opened.
Kind regards.
Denis
Dear Denis another file has uploaded kindly find in attached.
The file appears to now be an stl file.  I have limited access to the part.
Good day Osama Siddiqui
Welcome to PTC Community - it is a minor issue, but this should have been created as a question rather than a document.
Denis JauninDon Rawlins‌ - are you able to open the document?
If needed, this can be moved to Academic Support
Best,
Toby
I can open it but is an stl file and I'm not able to look at the geometry.  I probably wouldn't be able to answer the questions anyway but was hoping to maybe learn something from the discussion.
Don
