Hello!
I want to select features or references in an UI dialog for Wildfire 3.0.
It would be fine to have the same style like in the dialog for sketched curves or sketch orientation.
Do anyone know how to make these controls(InputPanels?) ?
Background yellow, click on it activates a selection... and so on.
Hope you know what I mean.
Greetings Lars
Hi Patrick,
good idea with the trailfile. It was not so easy to find out wich res it is.
But i got it. It was datum_sket_tab.res.
So i found out that it isn't an InputPanel.
Its not possible to change the background color by the API.
The control is a table. So i try to do that...!
Keep swinging,
Lars
