Eric, I have created a drawing template with my companies title block which includes parameters in a table for varying information. Example - Drawing Number, Title, and so on. My issue is, that when I start a new drawing and specify a template, when the drawing opens a menu manager prompts me to ADD PARAMETER such as Integer, Real Number, String or Yes/No. I want it to prompt me on the command line for the parameters I've specified. What do I need to do to eliminate the Menu Manager step? Is there a setting inside my Config.pro file that I need to modify, and if so, do you know what it is?
