Wave Spring
davehaigh
Wave Spring
I know I've made a wave spring in the past using a sketch relation, something like sd4=sin(trajpar*360*6)*.25
I'm lost on WF4 as to how to get started with the variable section sweep.
Help!
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
1 REPLY 1
davehaigh
(To:davehaigh)
Found my problem. I was looking for a way to sketch the trajectory inside of the variable section sweep feature. That's the way it used to work. Now you have to sketch the trajectory as a datum curve first and then reference it when you create your variable sections sweep.
Two features instead of one.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Livermore, CA 94550
