When I perform Edit Definition on the selected section of Creo model in Creo, Creo crash's
AA_11267387
2-Explorer
"Exception EXCEPTION_ACCESS_VIOLATION has occurred in the thread 16452."
8 REPLIES 8
BenLoosli
(To:AA_11267387)
What version of Creo?
Creo Parametric 7.0.5.0.
BenLoosli
(To:AA_11267387)
First thing I would try is a newer release of Creo 7. Creo 7.0.5.0 is over 2 years old. Creo 7.0.12.0 was released last October. I will say that we had issues with 7.0.5.0  and quickly upgraded to 7.0.7.0 when it was released, but the issues were not causing crashes.
Some other things to check are your graphics card settings and type. Is your graphics card certified by PTC and do you have the latest driver version?
Is this a new issue with all parts or just this one part?
Just only for one part
StephenW
(To:AA_11267387)
Can you share the part? (zip and attach to a reply)
If not, do you have surfaces? Or if your part section just goes thru a tiny area, sometimes that is an issue.
Have you tried deleting the section and re-creating it?
Yes, I have the latest driver version, and I also checked in different pc too
Is this a new issue with all parts or just this one part? only for this one part
Hi @AA_11267387
Can you share the part file and traceback file generated on exit?
Hi @AA_11267387
Did you get a chance to recreate the exit? If possible share the traceback and part file.
