Which constraint set
346gnu
Hi again,
Questions are thick and fast this week.
If I have a patterned part (20 times say) and that part has constraints and loads defined in it, does the order of appearance of the constraint and load sets in the analysis definition form appear in the order of the patterned part?
Example analysis definition form below showing a component's loadsets and constraint sets when patterned twice.
I know I can test but there is no way of telling which pattern element a constraint/loadset is associated with.
More than 2 elements in a pattern and it gets mighty confusing compounded by having to scroll up and down in the definition form as it's not possible to see more than 5 constraint sets/loadsets at anyone time.
346gnu
(To:346gnu)
Ahhh,
Switch on feature ID column in model tree and hover the mouse over the constraint/load
See pic below
Could the feature ID become part of the explicit description rather than the flyout?
1 REPLY 1
346gnu
(To:346gnu)
Ahhh,
See pic below
